first thing. i dont always get errors come on event viewer when it crashes or stops. which has happened since i got the comp cause i use to check it to see what was wrong but i get a few errors on it.
Error 1
SOURCE: a7mqvfw0
EVENT ID: 9
DESCRIPTION:The description for Event ID ( 9 ) in Source ( a7mqvfw0 ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: \Device\Scsi\a7mqvfw01.
the wierd thing about this one is that all my events are recorded in time and the one below this says 21:36:12. then this one says 21:35:13 and next is 21:36:07
error 2
SOURCE: service control manager
EVENT ID: 7000
DESCRIPTION: The ##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762## service failed to start due to the following error:
The system cannot find the file specified.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
error 3
EVENT ID: 7023
DESCRIPTION: The IPSEC Services service terminated with the following error:
The authentication service is unknown.
error 4
SOURCE: a5apeojl
EVENT ID: 9
DESCRIPTION: The description for Event ID ( 9 ) in Source ( a5apeojl ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: \Device\Scsi\a5apeojl1.
error 5
SOURCE: av2vebef
EVENT ID: 9
DESCRIPTION: The description for Event ID ( 9 ) in Source ( av2vebef ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: \Device\Scsi\av2vebef1.
error 6
SOURCE: altljx81
EVENT ID: 9
DESCRIPTION: The description for Event ID ( 9 ) in Source ( altljx81 ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: \Device\Scsi\altljx811.
error 7
SOURCE: Cdrom
EVENT ID: 7
DESCRIPTION: The device, \Device\CdRom0, has a bad block.
this is why i feel its my motherboard as everything was new.
also there are about 5 more errors like errors 5 n 6 since the 21st where as the 20th was ok
any help?
