Mobo CPU Como suggestions
zx6riz
20
Can somone suggest a good Mobo, CPU combo for a business PC. Running regular business apps, photoshop, burning DVD's things of that nature. Ive been running AMD's up till now but Id like to know if Intel would be more stable. My main thing is stability and speed.
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
There really isn't an issue anymore between AMD and Intel as far as stability goes. I have heard that AMD does well in some business apps whereas Intel does better in others. Simply cater to your needs, and your budget of course. I hav enever built a strictly business machine so the only input I can offer is the stability thing.
Dec 7, 2004
164
Can't go wrong with a Neo2 Platinum and 3200 Athlon 64.
Speed now, and 64 bit compatibility when the time comes.
3200 is about 240 on newegg
Neo2 is around 150 almost everywhere.
