Dell uses proprietary mobo made for them by Intel.
Hard to track down.
I'm sure it supports ATA 100
As has been said here many times - you will never see the dif between ATA133 and ATA100 in benches or real use.
If you really want ATA133 you get a Maxtor and a Promise add in card.
The biggest reason you need ATA133 is so you can make sure that you have the 48-bit LBA the controller needs to properly see the whole capacity of today's large hard drives that routinely exceed 137GB.
Originally posted by: VRXJudge
I'm gonna order a friend a new HD. I'd like to know what IDE his mobo would support, or if it matters (fairly recent PC, 1.5 years old tops).
