mobo choosing for i5 3470
KenJiNx
4
Hello! My native lang is Greek so, sorry for bad english
im making a new set
Case: Coolermaster HAF 932 Advanced 133.90 €
CPU: Intel i5 3470 Tray 174.91 €
CPU Cooler: Coolermaster Hyper 212 EVO 35.23 €
Im looking for Mobo
Asrock z77 Pro4 98.87 €
Asrock z77 Extreme4 126.8 €
Gigabyte GA-z77X-D3H 130.92
Which one should i choose and why?
You think any other to check? I want many Sata3 + usb3 and pci-e 2.0 16x
How you see the prices? Its from greek stores with NO ship fees
Thanks in advance
Sheep221
1,843
27
Since you won't be overclocking(locked CPU), You should not buy extreme motherboards as you would overpay for that badly. I would choose Asrock Z77 pro 4 from your list. This board seems decent with its price and features. If you will never plan to overclock at all you can also buy non-tuning chipsets (H77, B75) which beside overclocking offer everything same and these boards are much cheaper.
bononos
3,928
186
Thanks in advance
You're not going to get many choices if you want more than the standard 2 sata3/6gb ports and boards which feature 3rd party integrated chips for additional sata ports are typically oc'ing ones. B75 only supports 1 sata3 port natively.
You could consider a pcie adapter for more sata3 ports.
Torn Mind
12,044
2,763
You're better off getting a Haswell chip+ motherboard, since its chipsets usually support more SATA 6.0 Gbit/s ports. H87 and Z77 both support 6 SATA 6.0 Gbit/s ports natively.
KenJiNx
4
I agree, i dont need second vga card and OC options..
lets check some mobos from older chipsets, what you can suggest me?
Asrock H77/MVP ( 78 € ) : 4 x sata3 4 x sata2
what that means(asrock website)
- 2 x SATA3 6.0 Gb/s connectors by Intel®*H77, support RAID (RAID 0, RAID 1, RAID 5, RAID 10, Intel®*Rapid Storage and Intel®*Smart Response Technology), NCQ, AHCI and Hot Plug functions
- 2 x SATA3 6.0 Gb/s connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug functions
Only 2 ports is available for RAID?
Tell me more about haswell chip? What is that?
