mobo and graphics card incompatible?
rhin00
Recently I have purchased from NEWEGG.COM a motherboard K9N PLATINUM also I have purchaced graphic card ASUS EAX1900XT. After I assembled all the parts together and start runing the computer it did not POST and no information was showing on the screen. Then we muved the graphic from the main slot (white) to the secondary (yellow) and all worked fine. Afterwards we took out the graphic card and we put different(EVGA 7800GT) one in the main slot(white) and this worked fine. At the same time we put the original graphic card in other computer and it worked fine. After all those changes we could not get to any conclusion what the cause to the problem because each part can work separatly but not together (mobo and grapics card). They work togethe only when we put the graphic card in the secondary slot.
are they compatible and can work together?
