MOBILE AUDIO- ARC AUDIO 4 channel amp. FD4150. $399 SCORCHING!!!
Status
Not open for further replies.
This has got to be one of the best deals around.
I have this amp and I bought mine used at higher price than this. and it was worth every penny.
http://www.sonicelectronix.com/item...oogle&utm_medium=organic&utm_campaign=froogle
SE has this at an unbeliveable price. If you're looking for a 4 channel amp for you car this is it. For most people you won't be able to tell the difference between this and Macintosh. Some may argue, but i couldn't tell the difference.
With good Components you'll be blown away at the clarity of the sound that this amp can reproduce.
It's a great amp, but its just a 4150cxl in a different case.
I would imagine that that amp used runs for under 300.
Indeed. Most audio go through no changes for years...especially things like amps and speakers.
From what I can tell, that Clarion amp I linked, has been the same internally for quite some time. It has however, gone through 3-4 different visual changes.
Status
