I'm thinking of adding more RAM to my PC. Currently I have two RAM modules (I can install up to 4 modules). The RAM I currently have is: Kingston HyperX 2GB (2 X 1GB) DDR2-800 Dual Channel Kit KHX6400D2LLK2/2G. I would like to add 2 more modules of the same kit but the only online store I can find that sells that particular product is out-of-stock. I was wondering if I could add a different type of Kingston RAM instead and whether that would cause problems.
For example, there is this type of Kingston RAM: Kingston HyperX 2GB (2 X 1GB) DDR2-800 Dual Channel Kit KHX6400D2K2/2G. The difference is, the KHX6400D2LLK2/2G has CAS timings of 4-4-4-12 and is rated for 1.95V whereas the KHX6400D2K2/2G has CAS timings of 5-5-5-15 and is rated for 2.0V. I don't know all the intracicies of RAM so is it advisable to just stick to the brand and type of RAM my PC already has or can I mix the RAM around so long as it is the same brand and speed?
