mixing motor oils of different weight
Jul 10, 2007
12,041
i don't know what the garage put in and now i have to top it off.
it should be either 5w-20 or 5w-30, mobil1 full synthetic.
is it ok if i choose the wrong one?
PingSpike
21,758
603
I'm not a good person to ask, but I personally don't see how you could really screw anything up even if you used the wrong answer here. Surely, different weights and types of oils are mixed all the time due to the residue in the engine.
sdifox
100,250
17,895
Originally posted by: BlahBlahYouToo
Originally posted by: sdifox
call the garage?
it was a few months ago.
regardless, id oubt they'd remember.
Odds are you are fine which ever you pick. Most garage have a standard oil they put in, even for synthetic, so it should be that one unless you asked for something else, which you would hopefully remember asking.
StageLeft
70,150
I assume that one will float above the other but if both are fine for your car you'd just disproportionately use the one at the bottom, and in reality this would be a negligible effect, assuming they really do separate meaningfully in the shaking, vibrating oil pan.
bruceb
8,874
111
Both of those weights are very close and unless you live in Alaska where it will get really cold, either will be fine.
Just open the hood and look at your Oil Fill Cap ... most cars list the suggested oil on there. Use that or the 5W20
unless you are in very hot climate, then the 5W30 might be a better choice. And don't worry about mixing them.
They will work fine together.
LTC8K6
28,520
1,576
Yeah, it's printed under the hood somewhere. On the cap, or on a factory sticker.
The oil change place should also have put a sticker somewhere. On the door/jamb, corner of the windshield, etc.
But it doesn't really matter, go ahead and top it off with either one.
evident
12,130
749
i recently mixed 4 qts of 0w20 with .5 qt of 5w20. don't think it will make a difference.
Apex
6,511
www.gotapex.com
Either one is fine. Mobile 1's 5w20 and 5w30 are almost identical in true weight (in other words, one is on the very very thick end of the 20w scale, while the other is on the very light end of the 30w scale).
SparkyJJO
13,357
7
Actually they'd mix together, so mixing 5w-20 and 5w-30 would get you somewhere in between there, depending on what the ratios are.
