- Dec 29, 2010
- 3,034
- 1
- 81
Hi all,
For those who have a catleap or other 1440p 27" monitor, have you tried connecting mixed resolution and/or aspect ratios to see if you can get eyefinity or surround gaming to work? Does the catleap's lack of a scaler hurt it's ability to be used at lower eyefinity resolutions that would be needed when mixing with 16:10 or 16:9 monitors (e.g., side monitors of 1920x1200 resolution being run in 16:9 mode at 1920x1080 or lower resolutions)?
For example, how would eyefinity or surround work with the catleap in the middle, and two side monitors being 1920x1200? That's mixed aspect ratio of 16:9 in the middle, and 16:10 on the right and left (unless I'm mistaken on the aspect ratio conversions). Note that the 16:10 aspect 1920x1200 monitors I believe will support a 16:9 1920x1080 resolution.
So my guess is the eyefinity setup would drive all three monitors at the commonly supported 1920x1080 resolution, or other lower 16:9 resolutions, right? But, I'm really not sure because the Catleap doesn't have a scaler? Would I need to get the Microcenter version or other version that has a scaler? Ideally, I want to purchase the 1440p monitor around $300 and avoid spending more for the multi-input scaler.
Also, if anyone with Nvidia could provide advice, as I've never tried Nvidia triple monitor but I'm happy to use it if I can make this happen with Nvidia instead of AMD, it's just that I currently have an AMD card that I'm using for eyefinity with three other monitors @ 1600x1200 x3. I'm interested in eyefinity/surround gaming specifically, not just the multiple monitors for windowed desktop/browsing etc.
