Anyone familiar with this CD-RW. A top listed model on cdmediaworld.com. Used one last week and although slow, it seemed exceptionally reliable for those of use that don't do much burning. Would like info before I buy.
Mitsumi CR4804TE - relatively inexpensive CDRW, very slow by today's standards. Strong point is maximal compatibility with CloneCD. Considered very reliable by many system builders.
It also works with all the "weird" cd's like the ever elusive 99 and 120 minute versions. The 4804 is about the most compatible driver I've ever heard of (too bad the 4801, which I have, doesn't share any of these highpoints 🙁)
