MrBaseball
My brother managed to break a pin on his MAG 786FD 17" montor. Is there anyway to fix this?
EDIT: It ended up being the CPU was not seated well enough on the motherboard. Its a Slot A Thunderbird and it must have gotten knocked around a little when my brother moved. I should have taken a closer look at the computer before I posted 😀
It sounds like if you do break a pin on the monitor cable you are screwed. 😀 Luckily it was not that.
