- Aug 21, 2013
- 265
- 1
- 81
For some reason this message came up on my wife's computer when it was turned on this evening. She said that everything seemed normal this morning.
I am able to boot to windows 10 upgrade by pressing F11 selecting the hard drive with the o/s which is second on the list below EfI drive or something which I never quite understood from win 8.
The other drives listed are the second hd, optical drive and I think the RAM was listed.
On restart the problem has not fixed itself. I only have the windows 8 disk so I would need to find another way to repair the o/s rather than stick in the disk.
At the moment its late, I am tired and my brain is not with it enough to research a solution so I am throwing out the problem to the forum. In the morning I will read the replies if any. Thanks
