Missing Greyscale power saving option with Samsung Galaxy Marshmallow
wilds
2,059
674
I was shocked to see the Greyscale feature removed from Samsung's Galaxy S and Note series with Marshmallow. Battery life is the most important thing for me because I am often in the great outdoors, far away from a power source.
I was able to find the setting called Simulate Color Space in Developer Options and changed it to Monochromacy; which is essentially greyscale.
I just wanted to share this because there are a lot of upset Galaxy owners on the internet who want their Greyscale back. I was thinking all hope was lost for a moment. Power Saving Mode + Greyscale + 7500 mah battery = outstanding longevity.
Compman55
1,241
Does the "monochromacy" setting actually save battery life as a result of not having the gpu drive all those colors? Or does the greyscale emulation cancel it out having to calculate how to render it in B&W?
WelshBloke
32,882
11,025
You can access the greyscale option under settings>accessibility>vision
Not sure if it actually saves a lot of battery though.
KeithP
5,664
202
It doesn't. If you search you can find websites that have tested it.
-KeithP
