- Nov 29, 2000
- 3
- 0
- 0
I recently got a P4 and intel 850 motherboard.
I bought a 3dcool Tornado 2000 (which incidently turned out to be a great case), but I was told by 3dcool that it was compatible with the 850 (it's wasn't-I had to drill additional holes in the tray, modify cables and cuss).
Anyway, the motherboard has a normal ATX power supply connector as well as the new 4-pin 12volt connector.
The power supply sent from 3d cool is ATX only (without the 4 pin). Now, I called intel and asked them about using it and they said it was fine. The 4-pin setup was only optional(3dcool also told me this).
Every website reporting on the P4 is saying that you have to replace your power supply to the 4-pin 12-volt design to meet the new standard.
So, did the intel tech (as well as 3dcool) tell me a lie or is all of the sites misinformed???
