- Sep 29, 2000
- 70,150
- 5
- 0
65k miles on a 2004 MPV, original plugs. 18 months and about 15k-20k miles ago I got a code, no symptoms. It was a cylinder 3 misfire. I ignored it and the check-engine light went off and has been gone since. Today I started it up and quickly noticed that the light was on and there was some small hesitation when accelerating with a rough idle and just something off, like that cylinder wasn't working. I got it checked and:
P0108 MAP/BARO circuit high input
300 random/multiple cylinder misfire
303 cylinder 3 misfire
After 5 more restarts of short trips and another 15 miles the light is off. After the first trip the symptoms were gone.
It was pissing down rain yesterday and also very humid today. Is it plausible that some moisture is somewhere in an ignition coil (presuming this vehicle has 6, that is). If a plug was bad, it wouldn't have self-repaired, which is why I wonder if moisture is a problem somewhere...
Thanks!
Thanks!
