Mirror Bottom for case
I was looking for a mirror to put on the bottom of my antec super lanboy case so that the graphics card would be reflected. Does anyone know where I could get such a mirror, or be able to cut a mirror to size? Thanks 🙂
Hardware store, Home Depot, Lowes, Target, Marshalls, Steinmart, Walmart, K-Mart. Bring to your local yocal hardware store and they will cut it if they carry glass which most do. 🙂
Measure the inside of the bottom of your case and take the measurements to a hardware store that sells mirrors. You might want to take the whole case if your unsure about the measurements, like JBDan said. You could also get a cheap mirror at wal mart or a garage sale and cut it yourself with this Text If you want it on there permanantly I recomend construction adhesive or velcro if you want to remove it, all of these should be at a local hardware store.
~Matt~
