Miranda - AIM won't connect, help
gizbug
I've tried to use Miranda, but every time it tries to connect to my AIM, it never connects. It connects then disconnects. No idea why. Is there some setting or bug with Miranda when using it to try to log into AIM?
Using Miranda IM 0.8.0 Test 1
how long does it stay connected for? you may need to check the box "Send Keep Alive Packets" under Network -> AIM ... currently i'm using 0.7.1, i dont know anything about the 0.8 version
sorry for being a captain obvious, but have you tried with other IM clients?
I had something simlar going for a while at my old place.
At first we blamed miranda for it, then soon came to realize it was a common trait across all other messengers we threw at it.
is there a specific reason why you need to use that version?
the one I am using is 0.7.1 unicode and it works fine.
I would try uninstalling, purging the registry and installing a different version..
