Minor annoyance with dual monitor setup. Can't get mouse cursor to move right.
AnyMal
Here's the problem. My primary monitor (CRT) sits on the left, and the secondary (LCD) is on the right. I am unable to move mouse cursor from CRT to LCD by moving it to the right, instead, I have to move it to the left and then it will apear at the right edge of the LCD.
It's minor, but an annoyance nonetheless. I know the solution is probably very simple, but I'm having a brainfart and can't figure it out.
Originally posted by: cbehnken
Go into the display manager and drag the monitors to their proper orientation.
What do you mean by "drag the monitors to their proper orientation"? The CRT (on the left) is my primary monitor, that is where Windows troolbar extends from. What am I missing?
there is a picture of the way your monitors are setup in the display manager. Move your secondary monitor to the other side inside of the display manager.
Doh! Thanks! :thumbsup:😀
