minikitty needs some help with SetiDriver
Smoke
Distributed Computing Elite Member
Jan 3, 2001
12,650
207
Dear Greg,
My SETI driver stops running. What can I do?
minikitty
________________________
I've got to start the 1:00 PM Update. Will someone here try to help minikitty out?
Tarca
2,200
minikitty when does SetiDrive stop working? In the middle of the work unit or after it is finished with a WU?
IsOs
Have you tried to reboot?
How many workunits are you caching? Usually the culprit is a corrupt workunits.
minikitty
64
It stopped after finishing the fourth WU. Mine cache size is 5 WUs. I will try to reboot the machine. By the way, I use:
orangekid.teamanandtech.com, port 5001
as the proxcy server. It seems the program can't connect to the server.
minendo
35,560
22
<< It stopped after finishing the fourth WU. Mine cache size is 5 WUs. I will try to reboot the machine. By the way, I use:
I believe Orangekid's proxy might be down right now because I am also unable to connect as are some other members.
minikitty
64
I rebooted the computer, It still doesn't work. Do I need to change the proxy sever?
micron
You could try that. The list of TeAm proxies can be found Here
minikitty
64
Tried a few of them, none of them works. Moreover, it seems that the processed 4 WUs are missing:(. Where are the processed WU stored?
IsOs
Are you saying that SETI Driver is not showing any workunits in Ready to Transmit
Is there any workunit waiting to process?
How many need to fill?
minikitty
64
<< Are you saying that SETI Driver is not showing any workunits in Ready to Transmit
About one hour ago, it was showing that
"ready to transmit = 0"
" waiting to process = 0" and
"need to fill = 3".
By the way, I changed the cache size to 3.
After waiting to connect to the server for about one hour, now it is working.
"ready to transmit = 1"
" waiting to process = 1" and
"need to fill = 1".
I think the processed 4 WUS since yesterday afternoon are lost:(:(:(
CADsortaGUY
25,162
www.ShawCAD.com
The reason you couldn't get any WUs from my Q (mysterymachine.hn.org) was because bezerkely is really slow. and since you weren't already established you needed to wait until i was able to put WUs into your Queue. There are some in there now if you need/want a Queue to run through.
Also is this you? 64.187.15.98? If so then let us know whos Queue you will be running through because it looks like MaxSiren filled a Queue for you too( just like I did)
Update: OK's proxy is back up!!
Still over 2000 results backed up there, so we'd better give him a break for the next few hours.
Note: User connecting to siren.2y.net:5001 from 64.187.15.98
Your Q is full and ready.
<---MaxSiren from this THREAD
Also you may have upped a WU to anyone of us ...or all of us so your WUs will show up eventually - don't worry ;)
minikitty
64
<< Also is this you? 64.187.15.98? If so then let us know whos Queue you will be running through because it looks like MaxSiren filled a Queue for you too( just like I did) >>
No, it is not me.
<< Also you may have upped a WU to anyone of us ...or all of us so your WUs will show up eventually - don't worry ;) >>
If so, I will be very glad. I just want to make some contributions to our team.!
Eltano1
1,897
That's a cute name (Minikitty), I'm wondering if reflects your age or your height, or both, but anyways welcome to the team. :)
Best regards
Eltano
CraigRT
31,440
<< Also is this you? 64.187.15.98? >>
That was me from work... I hit a bunch of Q's in search for one I could get some work from, I was leaving for the day..
Smoke
Jan 3, 2001
12,650
207
minikitty,
I'm glad to see you have your SetiDriver problem worked out. The bandwidth situation is giving everyone fits.
I told you we had a great team and you'd get all the help you needed. :D
So don't be shy and let's hear from you often here in the DC Forum. And don't let anyone pick on you (or anything else) ;) ... if they do, just give me their name and I'll see they get 10 lashes with a wet noodle. :)
minikitty
64
<< minikitty,
Thanks! :). Thanks to all of you! I am very glad to be in a great team!
Eltano1, I like "Hello Kitty", that's the reason I figure out "minikitty".
Eltano1
1,897
Thanks for the explanation, and welcome to the team, and like the guys said, don't be afraid to ask.
Best regards :)
Eltano
