Mini ITX Power Supply for FreeNAS system
UnholyCarcass
45
I have an old emachines that I want to turn into into a FreeNAS system and was looking at replacing the power supply since it is an OEM one that came with the prebuilt system. I was looking around for mini ITX power supplies and all of them (on newegg and amazon) seem to have terrible ratings. Does anyone know of a great, reliable mini itx / flex power supply that I can buy from a reliable psu manufacturer?
Feb 25, 2011
16,991
1,620
What are the dimensions of the thing - are you sure it's an ITX / FlexATX and not some custom OEM weirdness?
Newegg seems to have a few FlexATX with pretty good ratings, but they're pricey.
UnholyCarcass
45
Hmm it may be some oem weirdness but im pretty sure a flex atx power supply will fit since the dimensions are fairly similar and if not I can just slightly mod the case to make it fit for sure. The thing is that I have never heard of those companies before and kinda hesitant on buying from manufacturers I have never really heard from before
