- Aug 13, 2013
- 8
- 0
- 0
First post on the forums! I've been a long time AnandTech viewer though and I'm excited to join the community.
Right now I am looking for parts for a mini-ITX build. I would like to go Haswell but I am not completely up to date with what is available and what would be best for my budget. Currently I have 4 Samsung 840 Pro drives, a stick of 4GB RAM Kingston HyperX and an OS I can use. I would like to go with the Core i5-4670k or the Core i7-4770k to do some mild overclocking.
What board, GFX Card, cooler and chassis would you guys recommend?
Requirements:
- Board must have built in wireless
- I would only like to go Haswell
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming and Video Editing
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1250 - $1500
3. What country YOU will be buying YOUR parts from.
U.S.A and Canada
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Intel
nVidia
8. What resolution, not monitor size, will you be using?
1920 x 1080
9. WHEN do you plan to build it?
ASAP
Requirements:
$1250 - $1500
U.S.A and Canada
Intel
nVidia
1920 x 1080
ASAP
