flexy
i know that for many this might be OLD news....but just in case...
If you have one of them cheap cases like i do....its WORTH it to spend a few minutes and remove the steel front/back fan grilles.
The fans are SO MUCH quiter and you get much better fan efficiency and airflow - for free !
I was surprised how easy this mod is..just take a plier and wiggle the connecting steel bridges 'til they break/pop...do this for all small steel bridges 'til the fan grill is seperated from the case and you have the opening without the grill.
CAREFUL !!!! Because you WILL have razor sharp edges/remains where the grill was... you can do this mod further and eg. sand the remains of the bridges down and put some tape/plastic around the opening so you dont cut yourself later.
This mini-mod applies for those old steel cases with the steel fan grilles...NOT the nice wire fan grilles. The wire fan grilles should be ok...you can also add one of those over the opinings afterwards usually.
