Hi all,
It's time for me to upgrade my render nodes and decided to go with a Mini ITX motherboard and i7 2600k combination. The CPUs will run on 100% for long periods of time as they will be used for rendering. I want to keep everything AS COMPACT AS POSSIBLE and for that reason I am going to need a low- profile PSU.
So, basically each render node will consist of:
Mini ITX motherboard (with integrated GPU)
i7 2600K CPU
4 GB DDR3
1 HDD 7200RPM
I will not use dedicated graphics card and will not overclock the CPUs.
Can you please tell me what is the minimum power supply that I will need. Then I will just add 50W to be on the safe side.
Thanks a lot, guys.
P.S. I used an on-line PSU calculator and the result was approximately 190W PSU. Is that result trustworthy?
i7 2600K CPU
4 GB DDR3
1 HDD 7200RPM
Thanks a lot, guys.
