B.Gen.Jack.O.Ne
APOLOGY FIRST: Hi, first, I know I asked here question about Gigabyte HD 6850 fan speed and temps, but since than I done too many things and found too many interesting stuff I had to create new thread. Please delete my old one.
OK, lets roll
So, again, hi there. I will cut the crap and lets fo technical...
I bought Gigabyte HD 6850 OC card. Fan speed seemed unadequate for me so I looked into CCC overdrive for its actuall speed. It was about 45%. Too much considering its cooler can hold it down to about 36 celsius in 35% fan speed. Just the speed I need to keep it quiet.
I started several attempts to change this.
Attempt 1: CCC Overdrive fan setting:
Nothing can be actually done here since it doesent dupport fan curve.
Attempt 2: Download BIOS and search it for its fan curve:
I downloaded BIOS using GPU-Z and read using RBE - found its fan curve starts at 52%. What? 52% and CCC shows 45%? What the hell? - should I thought... But I hadn´t....
Attempt 3: Edit BIOS, Flash BIOS:
I edited fan curve to my desired speed. After several programs that didnt work I managed to flash it using latest WinFlash. I started PC - sound quiter - I was excited, windows loaded, opened CCC overdrive and see what? 45% AGAIN?
Attempt 4: What if any other programs messing it up?:
I uninstalled EasyTune 6 and practically everything with ability to mess with fan speed. Of course with no effect....
Attempt 5: Listen where is the freakin problem:
I listened and found once the Windows 7 reaches some bootstage, possibly video drivers load, it goes up from BIOS curve to something....
Totally desperate move 1:
I made google hell with searching about everything on this problem, with every discussion I found ended unsolved. With suggestion like some hidden registry settings and so on....
WHAT DOES NOT MAKE SENSE TO ME:
Other people reported their HD 6850 from different vendors run at lower speeds like 32% and so - but I have fresh installed Windows 7, with latest Catalyst drivers, so where the hell is problem?
So I decided to ask this question almost everywhere, in hope we can together found what is cousing this. From my google searches I am not alone. Please help. Thanks.
OK, lets roll
