lehtv
- Dec 8, 2010
- 11,897
- 74
- 91
Just put everything together and noticed that the stock LGA 1155 CPU fan that came with the Dell is LOUD! Never noticed it in the old system for some reason. Any advice on what to replace it with?
Cryorig H7 looks pretty promising. $35 for a 120mm HSF with 6 year warranty, and a fan that runs at min. 330RPM allowing for silent idle operation and very low noise load operation. Most other 120mm fans start at 600-800RPM which can be audible depending on noise from other components and the case. It looks pretty sleek too and the shape is offset to avoid covering DIMM slots.
It's pretty massive though, close to Thermalright HR-02 size. But will easily fit inside your case.
EDIT: It seems to be a limited offer, not sure what the default price is. Alternative: Good ol' 212 EVO $30 AR
