Mighty Tank Graveyards
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Live ammunition is questionable, unfired would be more accurate. There are so many uses for old tanks. Location is always the hang up.
NAC4EV
1,882
754
I considered them live until proven otherwise.
Would you pull the pin on a unexploded WW2 grenade????
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
You misunderstand, I want things to go boom when they're supposed to. I just wouldn't trust them to do so. Only an idiot plays with old ammunition.
NAC4EV
1,882
754
I can agree with that.
I wouldn't trust them.
To be safe I would considered them live until proven otherwise.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
https://www.netflix.com/title/80208213 mentioned that it just wasn't cost effective to convert them for civilian usage, plus they have horrible fuel efficiency , i know i shouldn't trust tv shows but haven't seen anything else to contradict them
It's all about location. Of course fuel efficiency is horrible, their strength lies in their ability to burn damn near anything from salad oil to alcohol, diesel, kerosene, gasoline while producing enough power to run large generators, mills, combines etc. The cost of ingenuity is high in education which is short in the areas of these graveyards.
Reactions: KMFJD
Mar 11, 2004
23,444
5,852
WWII tanks? I know the turbine in like the Abrams can run on a wide variety of fuels, but weren't WWII era tanks running old diesels? They could probably be fitted to run other fuels but I don't think it'd be nearly as easy as you seem to think.
Which wow, Googling shows apparently a lot were using gasoline engines.
https://en.wikipedia.org/wiki/Comparison_of_early_World_War_II_tanks
Er, guess we're not just talking about WWII tanks.
