Mighty confused about memory speed timings !
vinayag
Im mighty confused by these memory numbers that I read in the forums. What does my Memory Timings mean as reported by Everest below ? What do the four numbers signify (I could make out that the fist one is CAS speed).
I tried my system at 1T and it seems stable. Should I tweak anything else ? Im not interested in overclocking, but want to run the system at full potential !!!
Field Value
Command Rate (CR) 1T
Memory Timings 2.5-3-3-8 (CL-RCD-RP-RAS)
Field Value
Memory Module Properties
Module Name ABACUS
Serial Number None
Manufacture Date Week 18 / 2005
Module Size 1024 MB (2 rows, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS)
@ 133 MHz 2.0-2-2-6 (CL-RCD-RP-RAS)
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 100 MHz (DDR)
Effective Clock 201 MHz
Bandwidth 1608 MB/s
Why is the speed showing as only 100Mhz ? Is this good enough or is the clock speed lower than it should be ?
I tweaked my setting in the bios to get this now :
Field Value
Motherboard Properties
Motherboard ID 63-0601-000001-00101111-050405-ATHLON64$A0128003_BIOS DATE: 05/04/05 11:33:55 VER: 08.
Motherboard Name Asus K8N
Front Side Bus Properties
Bus Type AMD Hammer
Real Clock 200 MHz
Effective Clock 200 MHz
HyperTransport Clock 800 MHz
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 201 MHz (DDR)
Effective Clock 402 MHz
Bandwidth 3215 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1 Socket 754
Expansion Slots 5 PCI, 1 AGP
RAM Slots 3 DDR DIMM
Integrated Devices Audio, LAN
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset nForce3-250
Extra Features Asus Intelligence, JumperFree, Stepless Freq Selection
So the memory is now running at an effective Clock speed of 400 MHz. But the AMD64 is capable of 800 right ? Or am I confusing the numbers here ?
On my version of everest, if I goto Motherboard, Chipset, and look at memory timings, it show the timings and the name together.
What tab are you getting the Mem bus Property from?
Im getting from Motherboard, Motherboard. As you said, Motherboard\Chipset gives me:
Field Value
North Bridge Properties
North Bridge AMD Hammer IMC
Revision 00
In-Order Queue Depth 8
Memory Timings
CAS Latency (CL) 3T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 8T
Row Cycle Time (tRC) 11T
Row Refresh Cycle Time (tRFC) 14T
Command Rate (CR) 2T
RAS To RAS Delay (tRRD) 2T
Write Recovery Time (tWR) 3T
Memory Slots
DRAM Slot #1 1024 MB (PC3200 DDR SDRAM)
What exactly did you change is bios? Your mem bus was at half-speed.
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 212 MHz (QDR)
Effective Clock 850 MHz
Bandwidth 6800 MB/s
Memory Bus Properties:
Bus Type Dual DDR SDRAM
Bus Width 128-bit
Real Clock 212 MHz (DDR)
Effective Clock 425 MHz
Bandwidth 6800 MB/s
This is mine. Look under chipset in Motherboard for something like this:
Memory Timings:
CAS Latency (CL) 2T
RAS Active Time (tRAS) 6T
EDIT: you did before I answered.
Go into bios and see if you can chage the CAS to 2.5.
Or your command rate to 1T from 2T.
Do you have good or low-priced ram?
If it is value ram, you may need to adjust the Voltage.
