- Jul 11, 2001
- 41,372
- 10,484
- 136
This machine used to boot fine, come out of suspend just fine. Usually it was an almost instant process to go to sleep or come out of sleep. Lately, progressively, it's been tough and now seemingly impossible.
The machine runs XP SP3 and there are 3 bootable partitions. The problem appears to happen in not just one partition.
I did some googling and saw some posts saying that a low CMOS battery can sometimes cause this. I replaced the ~3.17v (as measured with a multimeter) with a fresh one, but the problem persists.
In recent days even shutting down the system and starting from a dead state hasn't worked. I had to cut off power -- switch off the power strip that the system is plugged into, then switch it on and only then start the machine to get the machine to boot. Once booted, the machine appears to work OK until I try to either suspend it or restart it, which fails. It seems to suspend OK, but taking it out of suspend, the machine starts up but I get no video. It just sits there and the video never shows up. One time a couple days ago Windows seemed to almost awaken but it didn't get to the password check, it just sat at a sky-blue screen.
I'm thinking it's likely the PSU, but maybe the mobo. Am I right there?
Basic specs:
Gigabyte GA-K8n Pro motherboard Specs: http://ee.gigabyte.com/products/page/mb/ga-k8n_pro/ PDF of manual: http://download.gigabyte.eu/FileList/Manual/motherboard_manual_k8npro_e.pdf
AMD Athlon 64 3200+ (socket 754, FSB1600, E6, Venice, 90nm, L2-512KB, 2GHz)
BFG Tech GeForce 6600GT OC 128MB DDR3 AGP Dual DVI Video Card w/TV-Out
3 sticks Crucial 1GB PC3200 400MHz 184-pin DDR Memory - CT12864Z40B, 3 GB total
Corsair vx550w PSU
USR Model 2977 PCI hardware modem
Hercules GTXP soundcard PCI with breakout box
MyHD MDP-130 HDTV PCI
MyHD MDP-130 HDTV DVI daughterboard
Windows XP (word is that's the most advanced version of Windows the motherboard supports)
I'm researching rebuilding the system, getting a different mobo, CPU, RAM, video card and maybe PSU too. Also Win7 32 bit (the HDTV cards require that and nothing better, so I'm held back on components/OS for that reason. Meantime, I'd like to be able to use the machine in the way I'm accustomed, I set up automatic recording of HDTV shows coming out of suspend. Right now, even when the machine isn't in suspend the automatic recording doesn't seem to happen (didn't yesterday). And if suspended, the machine will not reawaken, period.
I am conquered by truth. - Desiderius Erasmus
Basic specs:
Corsair vx550w PSU
