- Apr 17, 2001
- 897
- 58
- 91
So I do have experience building PCs, I built one almost 5 years ago but am now running old ass Athlon X2 machine with 1 gb of ram on Win7... but its starting to suck a bit and I can hardly play any games anymore so i need to upgrade.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Basically web browsing, various apps,watching Divx movies on my HDTV (dual screen output) and gaming... nothing intense except the gaming
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I'd prefer to spend < 600 but if its worth it, i will spend it
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
monitor, keyboard, mice, speakers, dvd-rw, hard drives
6. IF YOU have searched and/or read similar threads.
read a bunch about cpus and stuff... still catching up though
7. IF YOU plan on overclocking or run the system at default speeds.
probably default for now and overclock as it gets slower???
8. What resolution YOU plan on gaming with.
widescreen resolutions
1200x960 or whatever it is.
9. WHEN do you plan to build it?
by the end of the year
Everything is flexible right now but this is what I have so far:
CPU:
Intel Core i5-750 - $150 at Microcenter
(I am picking this over a x4 because i can get the cheap deal at microcenter.... But I am open to the x4 or something else if its worth it overall... dont really care)
HSF: Stock, I don't plan on overclocking now... will it be sufficient?
Motherboard:
GIGABYTE GA-P55-UD4P for 170...
best reviewed P55 board i saw... I am concerned about that foxconn socket issue... is that relevant here?
RAM:
G.SKILL ECO Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model - $97.99
(I picked this because it keeps popping up in similar threads to mine, it has low voltages,etc. is it worth it to get the Ripjaw model instead??)
Video Card
XFX HD-489X-ZSFC Radeon HD 4890 1GB
175 AR
(From what I have read this is the best value mid-level card out right now...) or i might ge the Radeon HD 5770 for about 155.... but i think the performance increase is worth 20 dollars eventho its alot bigger and uses alot more energy w/o DX11
PSU
CORSAIR CMPSU-550VX 550W
$70
(seems like this is the consensus for a good PSU that is *cheap*)
Case
Antec Two Hundred or Three Hundred
$40 or $50
These seem like good value priced cases that don't have a bunch of extraneous crap I don't need. I am open to suggestions tho. I want a mid ATX case though. and I don't need windows, LEDS, etc etc
Total: ~ 735 + maybe another HD
Besides getting comments on my components:
1)Do I need to get a fancy heat sink if I don’t plan on over clocking right now?
2) the p55 foxconn socket issue... is that going to be a problem for me?
thanks!
USA
No preference
CPU:
Motherboard:
RAM:
Video Card
175 AR
PSU
$70
Case
$40 or $50
thanks!
