tjpark1111
AMD 3000+ Single-Core Socket 939 Venice E3 1.8 Ghz 512KB 90nm MicroProcessor - $111 shipped @ NewEgg
EPoX 9NPA+ Ultra nForce4 Ultra ATX Motherboard - $98 shipped @ ZipZoomFly
OCZ Value Series 184-Pin DDR SDRAM DDR400 PC3200 2x512MB 2.5-4-4-8 Memory - $79 shipped @ ZipZoomFly
ATI R520 Sapphire X1800XT 512MB GDDR3 PCI-E 16x Video Card - $285/$255AR shipped @ NewEgg
Zalman USA VF-900 Cu VGA Cooler w/80mm Fan and 2 Heatpipes - $40 shipped @ NewEgg
Western Digital Caviar SE16 320GB 16MB Cache SATAII 3.0/Gbps 7200RPM Hard Drive - $126 shipped @ ZipZoomFly
Antec Lifestyle Series Sonata II Black Silent ATX Mid-Tower Case w/SP-450 ATX12V PSU - $101 shipped @ ClubIT
ViewSonic VA1912wb 19? 8ms Widescreen (1440x900) 500:1 LCD Monitor - $258 shipped @ Buy.com
Logitech X-530 Black 5.1 Surround Sound Speakers - $60 shipped @ ZipZoomFly
Components from Various Vendors - $1158/$1128AR shipped
Thermalright SI-120 Aluminum CPU Heatsink w/5 Copper Heatpipes
2 120mm Low Speed Black Yate Loon D12SL-12(1350rpm, 47cfm, 28dba) Case Fans
3.5g of Arctic Silver 5 All-Silver Thermal Compound
30ml Articlean 1 and Articlean 2 Thermal Compound Remover
Zalman ZM-NB47J Blue Aluminum Passive Northbridge Heatsink
Thermalright XP-120 Heatsink 120mm Fan Replacement Clips
Components from Jab-Tech - $75 shipped
Total System - $1233/$1203AR shipped
Comments:
I'm following the mid-range anandtech budget of around $1250, what do you guys think?
I've been researching for quite some time now, reading up on articles all over the net, and that's why I only have around a hundred posts. For my uses, single-core and 1gb of ram should serve me fine for gaming and other just basic tasks. The route to ATI is partly because of the price, better image quality(HDR+AA), equal to better performance, and ATI's Avivo being very efficient at video encoding and decoding, MUCH more so than NVIDIA's PureVideo technology. I know about the voltmod on the 7900GT but I am a newb and I just have a bad feeling about messing things up even with everything stock. When I feel a bit more confident about computers maybe on my next build, I'll go for v-mods. About $55 would go into a conductive pen, a digital multimeter, and an nv silencer, so by then I would rather get an X1900XT. For some more experienced users, I understand how the 7900GT's are selling like hotcakes, running almost as fast as an X1900XT after the v-mod, much cooler running cores, smaller profiles, and better warranties. I think I'll be satisfied with the X-530 speakers and the onboard sound since I'm not really disappointed with some cheap headphones on the crappiest onboard sound ever on some laptop. Every other component seems self-explanatory, with the epox board a good overclocker to bring the 3000+ up, the value ram(i dont care about dividers), a large hard drive for all the media, an expensive but excellent zalman cooler that'll last me quite a bit of time, one of the few quality cases that include a good power supply and with a very reasonable price tag, and a widescreen monitor that has excellent reviews and the same or cheaper price than a 4:3 monitor. I just isolated most of the accesories to jab-tech since they had pretty good prices, and the reason for the SI-120 and not the ninja is because the SI-120 gives much more airflow to motherboard components(VRM, MOSFETs), directly relating to stability on higher OCs and longer life. I'm not sure if the passive zalman on the northbridge will sustain overclocking, anyone have any comments? A 120mm fan will be near it as an intake. Thanks for all of your expert help guys.
UPDATE: looks like a $30 rebate just popped up on the sapphire x1800xt, more $ saved for me!
Comments:
