justaguy168
Please comment on this build:
Rationales & Questions:
- 1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Light MS Office 2003, & Quicken, (no multi-acre spreadsheets here, Yahoo mail, Streaming iTunes audio, streaming video from YouTube / Netflix / Hulu. Needs to have dual monitor so can view bank statement and Quicken simultaneously. There are minor vision / acuity issues here. - 2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Around $600 including two new monitors. If the build burns out in two years than it's too cheap and not worth it. Am looking for a base level of quality here but not much more than that. - 3. What country YOU will be buying YOUR parts from.
USA have centered around Newegg but willing to go to other e-tailers or retailers in NYC area. - 4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference but the AMD / Zacate / Hudson route seems most economical. - 5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Keyboard, mouse, speakers. - 6. Not on sticky
Why? - 7. IF YOU plan on overclocking or run the system at default speeds.
Default speeds. - 8. What resolution will you be using?
2 LCD widescreen monitors 1366 x 768 each - 9. WHEN do you plan to build it?
ASAP - 10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Need to purchase Windows Home Premium. Already have Quicken and MS Office 2003.
Code:
Price Component Newegg # / Link Desc
$65 Case/PSU [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16811133093&user=u00000687"]N82E16811133093[/URL] Thermaltake Element Q VL52021N2U Black SGCC / Plastic Mini-ITX Desktop Computer Case 200W SFX Power Supply
$7 Case Fan [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16811999069&user=u00000687"]N82E16811999069[/URL] Cooler Master SAF-B82-E1 80mm Case Fan
$94 ITX Mobo [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16813157228&user=u00000687"]N82E16813157228[/URL] ASRock E350M1 AMD E-350 APU (1.6GHz, Dual-Core) AMD A50M Hudson M1 Mini ITX MOBO/CPU Combo
$42 Memory [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16820134928&user=u00000687"]N82E16820134928[/URL] Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model KVR1066D3N7K2/8G
$85 HDD [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16822145531&user=u00000687"]N82E16822145531[/URL] HITACHI Deskstar 7K1000.D 500GB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Bare Drive
$38 ODD [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16827249071&user=u00000687"]N82E16827249071[/URL] PLEXTOR Internal CD/DVD Multi Burner SATA Model PX-L890SA
$190 Win 7 OS [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16832116716&user=u00000687"]N82E16832116716[/URL] Microsoft Windows 7 Home Premium
$521 Subtotal
$176 2 Monitor [URL="http://redirect.anandtech.com/r?url=http%3A%2F%2Fwww.bestbuy.com%2Fsite%2FAsus%2B-%2B18.5%2522%2BWidescreen%2BFlat-Panel%2BLED-LCD%2BMonitor%2B-%2BBlack%2F1623903.p%3Fid%3D1218273846967&user=u00000687"]1623903[/URL] Asus - 18.5" Widescreen Flat-Panel LED-LCD Monitor - Black [URL]http://************/7g5vhbb[/URL] (Asus 18.5" Best Buy)
$16 NYC Tax 8.875%
$713 TOTAL not including extended warranty
- ITX vs mATX: Newegg is pushing the ITX combo boards and giving good deals on them. Makes it cheaper then a mATX setup. Going with a mATX solution was actually more expensive. Cheapest cases / mobo in my performance range were Antec Minuet w 350W PSU and ASUS E35M1-M PRO Fusion Hudson Mobo. That subtotalled $50 higher at $565. This post was interesting but I think it is too underpowered. I'd also be interested in the forum's comparison.
- Case: fits an ITX board and a 5.25" optical and 3.25" hard disk drive. I'm quite worried about the quality and sufficient power of the CPU. I chose the Thermaltake case because Newegg has been touting it on their YouTube channel and it seems to have the best price / performance point. Another option is the InWin BP Series Newegg part number N82E16811108396 or N82E16811108196. Another thread in this forum seems to think a Zacate E-350 system should come in under 60 watts. So a 220 PSU should be fine, no? Will mod the case with an extra 80 mm fan. This CoolerMaster fan seemed to move the most air at a reasonable noise level? What do others think?
- Mobo: has right price performance point. Was originally going to go with an i3 but opted for this because I think performance will be what I need. According to page 16 of their manual it does support dual monitors. It seems there is tremendous economy to buying the board and CPU together.
- Memory: I believe this is one of the chips explicitly listed on ASRock's compatibility manual on page 3 here. One place where my knowledge is weak is with memory timing and performance. I would especially welcome input from the forum here.
- Hard Disk Drive: My parents arent likely to save a lot of graphics and video. Dad's audio collection is not large. I was able to shave a few bucks off off by going with the 500 GB over the 1 TB which I think will be plenty large. Tossup between WD Blue and Hitachi. I chose Hitachi because I heard it was inexpensive, has a bigger cache and shipping is free. It is one of the big 4 (Seagate / W Digital / Hitachi / Samsung).
- Optical: This is the main moving part and I don't believe in chintzing here. In a highly commoditized niche I have heard the best things about Plextor.
- Monitors: least expensive but monitors I could find. One will use the DVI-D port and the other will use the Dsub port. Feel the need to go with local brick-and-mortar store here in case of defects. Shipping / sales tax is probably a wash. Interested if folks think these monitors are too low quality. See related discussion on this thread. Is LED worth it?
- Extended Warranty: Are they worth it? For which components?
- Custom vs. store-bought: As far as the rationale behind build instead of buying a Dell or HP: I've been pretty soured on the tech support from both and do not look forward to pulling off all the crapware only to be told "we only support our configuration" if something goes wrong. Also economically, their margins are too small to make putting quality parts in worthwhile. In the end, I can get a box that better meets my needs and is easier to support for cheaper if I do it myself.
