Wyndru
A few months ago I bought a new microwave that has been disrupting our WiFi signal each time it is on. I've searched around on the web and have found some sites that say this is normal (since they operate in the 2.4ghz range) and other sites that say this is abnormal (even dangerous) because they should not be leaking anything that would cause an interruption in wifi.
I did the cell phone test of putting the phone in the microwave and pinging it as well as calling it and both worked, so basically it doesn't appear that the microwave is shielding any signal from getting into it. I've seen this test suggested around the web and I don't know if it proves anything or not.
When I say I lose wifi connection, I don't mean the signal gets weak, or I just lose some packets, I mean I completely lose signal anywhere in the house until the microwave has stopped.
Is this anything I should be worried about? Is there any way I can shield this, or should I start shopping around for another microwave? My wife is pregnant, so that's another concern I have, she uses the microwave quite a bit, and often stands by it while it's on.
