Microsoft products, FTW!
When I first tried to install IE7Beta1, WGA failed and said my copy of Windows wasn't legitimate, even though it's the one that came with my Dell.
I just installed IE7Beta2, WGA passed.
Consistency, FTW!
If you install IE7B2, does it overwrite IE6? Or do they co-exist and you can uninstall IE7 at any time w/ no problems?
It overwrites as an update, so you can uninstall IE7 and keep IE6.
Originally posted by: MX2times
I guess you posting your experience in that IE7 thread that Dug777 wasnt enough🙁
That was for Beta1. Anyways, this is completely un-related.
But I must say, aside from that small problem, the only thing I dislike from Beta 2 at this point is the location of the class menu. It should always be at the top. It's pretty fast.
Interesting. Winamp stopped working alltogether, restarted to see what's up. Still didn't work; task bar kept disappearing but the process was still up. Stopped/Started explorer.exe multiple times, same problem. Removing IE7Beta2 now. 🙁
Congratulations.
In a mere thirty minutes, you've successfully proven you haven't a clue how to evaluate an application.
Originally posted by: ActuaryTm
Congratulations.
So far, IE7Beta2 has screwed up my machine within 10 minute, even after re-installing. What do you expect my evaluation to be?
Congratulations.
That you give up easily?
