Microphone wont work
xNIKx
405
Ok so i wanted a headset so i decided to try a old headset i had laying around.
so i unplugged my mic and speakers and plugged in the headset, which didnt work.
so i plugged my speakers and mic back in.
the speakers work but the mic wont.
so i bought a head set, figured as long as the headset mic works it wont matter.
but it doesnt. the headset works but the mic wont.
can anyone help?
Roguestar
6,045
Assuming windows vista (XP is probably similar), right-click on speaker icon in system tray and select recording devices. If it's in the list, fine. Click properties, and ensure the drop down menu option selected is "enable this device".
xNIKx
405
i have xp 32 bit, i dont see the recording devices in the speaker icon in the system tray.
Roguestar
6,045
Start -> Run: "sndvol32"
Make sure "mic" is visible as a volume slider, make sure it's not muted.
