MicroFly/P180 Owners: Temps???
PianoMan
If I'm not mistaken, larger cases have typically lower temperatures (better airflow?). I've been truckin' around with this MicroFly, mainly for ease of transportation as I relocated recently, with the following CPU/NB/Sys temperatures: 48/49/44deg C. at around a 80deg F. ambient room. Everything's stock speed, so I'm wondering if moving to a larger case would be a good move, especially when I start upping the clocks.
Other MicroFly/Q-Pack owners - are these temps comparable? For the P180 owners - are these much higher than what you all are running?
Are there other cases with separate compartments that are worth looking at?
PM
I have a DFI lanparty UT SLI-D running at 325Mhz FSB, X2 3800+ running 2.6Ghz, 2GB Mushkin DDR500 @ 540Mhz, X1900XT @ 360/775, Zalman CNPS 9500LED, Evercool VC-RE Chipset cooler, P180 with all the fans on lowest possible.
My temps are as follows at idle right now with about 80F room temp CPU38c, chipset 47c, case temp about 46-47c (varies slightly). At full load my CPU goes to 50c and chipset to 55c.
I also run my voltages at 1.45v for cpu, 2.7v for memory, 1.7v for chipset.
Thx cmd,
Slightly lower, but then again, you're running a bit more on the edge than me. 🙂
Noticed your X1900XT's at 360 - a bit low? Is that because your FSB's cranked up?
PM
Originally posted by: PianoMan
Thx cmd,
PM
No it's because ATI tool crashes, ATI Tray tool doesn't work, and ATi Overclocker resets to 2D clocks all the time so I'm stick with Overdrive through the CCC.
And my X1900xt has the crapo elcheapo primo Infenon memory not samsung :frown:
