Micro-ATX with front USB?
Hork
531
Anybody know of a micro-ATX case with USBs on the front? The smaller the better. The more USB ports the better.
DieHardware
1,706
You can add a front jack panel(USB and/or firewire and/or sound jacks) as a option with the Aopen H340 series mATX cases.
Squisher
21,204
66
Nice job, SnowPunk and now you've given me a reason not to do my taxes this weekend(hehehe).
optimistic
3,006
link. You gotta buy the usb header separate. But's there's space for two in the front. Case comes in at $58. The header is $6.
mobly99
260
I'll have my Lian-Li PC-42 next week sometime if anyone has any questions on it or want s pics. Biggest mATX power supply I found was a 200W one direct from enhanceusa.com (ENP-2120A)
lamga
119
Most Nikao cases like the MT-2000, 3000 series have hidden front panels with USB, microphone and headphone jacks. They're steel, so a lot less expensive.
nnnyyy
3,370
this is what I have. Looks nice (especially for the living room), smallest micro atx case that holds full sized cards. Just a little bigger than a book pc, has front usb ports (with an addon). The 200 watt ps is good enough for an xp1600. Price is very reasonable also.
MCS
2,519
Another vote for the A102, I have this case in black for my living room PC and it is of a high quality build. The USB headers are not included, however.
DongTran
2,277
<< this is what I have. Looks nice (especially for the living room), smallest micro atx case that holds full sized cards. Just a little bigger than a book pc, has front usb ports (with an addon). The 200 watt ps is good enough for an xp1600. Price is very reasonable also. >>
That's a really nice case. I almost bought it when it was on sale for $50 @ my local PC Club in San Diego, CA, but they sold out so I said forget it. A few more rants, I wish it came with standard ATX power supply so that I can slap a sleezy enermax in there, and I wish it came with no floppy as those are useless to me.
Also, in case anybody is wondering, that case is an In-Win model L545. Here are full specs:
specs
you could probably tell I did some research :)
optimistic
3,006
<< Also, in case anybody is wondering, that case is an In-Win model L545. Here are full specs:
specs
I bought that case for $49 at PC Club link. It has the same quality construction as the Yeong Yang A102, but has built-in front panel USB headers. Comes with the necessary wiring to connect to your motherboard. Also I like not having a door in the front to hinder access to the CDROM. Color is nice. A blue mettalic shiny front benzel on a clean white/beige case. But you have to be careful with heatsink selection with these cases. Because of the side mounted CDROM, I measured you have only 3 inches clearence from CPU socket to the CDROM. MEANING, you can only use heatsinks no taller than 3 inches!!.
The L545 comes with an Inwin 180w SFX PSU which can support Thunderbird up to 1GHz and Duron up to 1.2GHz according to AMD Configuration Info.
The A102 comes with a 200w SFX that can support Thunderbrid up to 1.2GHz / Palomino up to 1700+ & Duron up to 1.3GHz.
I'm not sure about intel power requirements.
AU Tiger
4,280
The L545 is also at EMS Computing for around $43. Can choose between blue and gray fronts (I don't know if the gray is the silver one pictured on inwin's website).
