micro-atx question
grygrx
231
This seems dumb, but I need validation before I do something bad. Will a micro-atx be ok in a normal Atx case? I'm thinking yes, but I'm unsure.
Adam
sohcrates
7,949
you got me worried! so i found proof from the directron website:
"A micro-ATX case has smaller footprint and much fewer expansion slots (typically 3-4) than a regular ATX case (typically 6-8). MicroATX cases require special micro-ATX motherboards. However, a micro-ATX motherboard will fit inside a regular ATX case. Not all microATX motherboards have the same physical sizes. Check out the sizes before purchasing. Some microATX cases use normal ATX or mini-ATX power supplies while some use microATX ones.
so basically, you're hooked up!
