maker says it's 90mm X 56mm X 14mm which - for us poor UK colonies still suffering under cubits, stones, and feet - equals 3.54 x 2.20 x 0.55 inches.
That's big, but did ya'll notice the little screw that *may* allow easy swapping of the FC inside? That would be a big bonus for me as the card could do double duty as cam-storage and the body used to host any number of FCs.
If anyone has one of these things and is willing to pop it open I'd like to know what your observations are - and the FC it came with.
