CAN A MSI MB KILL THE LAZER POINTER IN A MOUSE ?
Razer Copperhead + new cheap OCZ eclipse died no pointers.
I just got my new Razer Copperhead not sure if I should plug it in.
When I raise my fsb over 396 500 or have cpu volts on low side.
During the start of booting on my MSI PC it hangs or stops at times as the USB initializes.
When the usb tries to initialize you can see the lights on Saitek pad go off and on a few times.
Tried few PS2 mouse and keys same problem maybe less.
4 sickes of Ballistix doesnt help either,run it at 800.
MSI PC is on 24 7 no problems If I do a restart it usually will start.
If I shut it off to clean etc.it can be a bitch to start.
But I to never shut it off just Worried about my new mouse.
