- Apr 27, 2000
- 23,240
- 13,327
- 136
Labtec Verse 504 el-cheapo desktop mic
I purchased this product to replace an apparently-broken Labtec AM-242 mic for use with my Creative SoundBlaster PCI soundcard(actually an Ensoniq AudioPCI with firmware update; may have ruined card's record fuctionality?). The new microphone produces the same problem . . . no sound recorded. Only static is heard in Windows sound recorder(yes, I have double-checked all my multimedia settings, maxed mic volume, activated and deactivated mic boost, used various degrees of hardware acceleration for recording, etc). I also have an on-board AC97 sound chip(ECS K7S5A motherboard), and I enabled it and installed drivers from Windows Update(now I have two sound devices active, both produce good output for speakers). The mic does not function when plugged into the AC97 mic jack, and doesn't even produce any static. Oddly enough, when the mic boost is activated and the Ensoniq/Soundblaster card is used as the recording device, and the mic plug is positioned properly inside the mic jack, my speakers produce a loud buzzing noise, and this noise is present in all recordings(that's the ONLY thing present). I am thinking this may be a problem of getting enough power to the soundcard and/or AC97 chip, or maybe the loud fans in my computer are causing problems with the mic? It's an Athlon 1.4ghz with two case fans and a fairly noisy generic cpu/heatsink. Sounds like a small vacuum cleaner.
