Yeah just grab a guard by the neck (square when behind them) and drag them over there, if he starts to shake and stuff tap x, make sure he stays concious. drag him over the the retinal scanner and eventually it will go to a cs and you'll be let in
Edit Ok maybe not. I went the wrong way I guess cause I keep coming to two locked doors. Ok now I am trapped in a tunnel with one door on each end that is locked and a door in the middle that is locked. What do I do? I cant get out.
