randomrogue
- Jan 15, 2011
- 5,462
- 0
- 0
How do you change its velocity?
at this point we can do fuck all about meteors, so anything really would better than what we currently have. One day a big one WILL hit and WILL kill all life left on the planet, whether we'll be around to see it is the question.
I want to make a point about shrinking NASA funding vs. welfare/stupid wars but I'd rather not turn this thread political, although I guess I just did...
A couple of different ways.
Don't laugh but you could paint one side of the Aestroid and this would cause the sun to heat one side of the Aestroid more than the other which can cause a change.
The other way is to use what is called a gravity tractor. You put in orbit around the Aestroid a large spacecraft with sufficient mass. The spacecraft and aestroid would mutually attract each other. If the spacecraft had some type of propulsion like a Ion drive it could drive it's self slowly away acting against the gravity force of attraction. This would slowly cause the aestroid to pull itself in the direction of the spacecraft which would change it's velocity. All you need to do it's change it velocity by a tiny bit.
If I saw that I would definitely think it's a nuke (watching first vid) even though I have no idea what their reentry looks like.
the meteor impacted nothing. It exploded pretty high in the sky and broke into small pieces. What caused destruction was the shock wave.
Here's the video of when the shock wave hit the ground:
http://www.youtube.com/watch?v=b7mLUIDGqmw
Interesting. Step one is a spacecraft though. So lets invest in an actual space program. If anything we should have something for humans within the solar system and an unmanned probe program for outside the solar system. If/when we get fast enough propulsion we can start looking outside the solar system.
We should elevate further or funding of the tracking of asteroids.
We should also elevate further or funding of missions to asteroids with the eventual go of being able to change the velocity of a asteroid in case we do find one on a intercept course.
Maybe this incident will reduce some of the giggle factor when there is talk about methods to track and asteroid intercept.
That was the shock wave? They had a mythbusters episode where they wanted to prove whether supersonic shock waves could break glass. The only way they could get it to happen was with a fighter jet at Mach 1.03 flying 200 feet above the ground. That was because it warped one window frame too. Was very anti-climatic.
These things happen all the time. We just blame them on terrorists. Oklahoma city, New York and the Pentagon, USS Cole, Beirut barracks, Kenya Embassy, etc.
The Dorner cabin was not set on fire by the police. That was a meteor too.
That is change the trajectory not the velocity. Much easier and efficient.
Whatever is easiest to affect the course of the Meteor/Aestroid. You only have to nudge it a little bit if you detect it far enough out to get it to miss the earth.
Meteors don't explode by themselves in mid air. They break apart. But explode nope that Bullshit
Yes they do. All the time. Tunguska even is a prime example of this in modern times. If the body is filled with ice or frozen carbon dioxide which then gets superheated as it streaks into the atmosphere an explosion is not all that surprising.
Try putting thermite on ice and see what happens.
wow so that ice so cool it didn't melt going through the earths atmosphere?
