Metal Gear Box Raid 3.5" USB2.0+FW 800+1394 Dual HD Enclosure
Pardus
8,197
21
GALAXY 3500MGBR BLACK METAL GEAR TWO 3.5" SATA HDD RAID EXTERNAL ENCLOSURE USB2.0 & FIREWIRE (BLACK)
When it comes to raw power there is nothing to beat the dual-bay 3500 Metal Gear Box Raid. The 3500MGB-Raid is built strong and rugged, offering more than enough capacity to store all your digital media files. Not only that, the 3500MGB-Raid can also back up and secure all of your data thanks to RAID protection. Great performance, great protection and great looks ? only in the 3500MGB-Raid. Model No. 3500MGB-RAID Bridge Chipset: Oxford 924 DSB Colour: Silver/Black Case Material: High quality aluminium for optimised heat dissipation
Product Feature
Application: Two 3.5" SATA-I or SATA-II Hard Drives (1.5Gb/s)
Identical hard drives recommended (same manufacturer, capacity and RPM)
Configurable RAID function for 2 drives (RAID 0 using striping or spanning or Non-RAID)
USB mass-storage compliant (USB 2.0 and USB 1.1)
Supports Firewire 400 and 800 (hardware acceleration for FastStart & small data blocks) 18-Kbyte cache for USB or Firewire data maximizes performance by double-buffering 4-Kbyte packets
SATA II compliant
Interface/Ports:
FireWire 800 (1394b) 2 ports
FireWire 400 (1394a) 1 port in front
USB 2.0 High Speed (USB 1.1 compatible) 1 port
Data Transfer:
Firewire 800 (1394b) up to 800Mbps (100MB/s)
FireWire 400 (1394a) up to 400Mbps (50MB/s)
USB 2.0 up to 480Mbps (60MB/s)
USB 1.1 up to 12Mbps (1.5MB/s)
System Requirements(PC):
FireWire 800 (1394b): Windows 2000/XP
FireWire 400 (1394a): Windows ME/2000/XP
USB 2.0: Windows ME/2000/XP
USB 1.1: Windows ME/2000/XP
Your hardware device must have the correct corresponding port (eg. USB 2.0, USB 1.1 or PCI card).
System Requirements (Mac):
FireWire 800 (1394b): Mac OS 10.2 or higher
FireWire 400 (1394a): Mac OS 9.1 or higher
USB 2.0: Mac OS 10.2 or higher
USB 1.1: Mac OS 9.2 or higher
Power Supply:
External Power Adapter universal auto-switching (UL, cUL, CE, TUV approved)
Input: AC 100-240V
Output: DC +12V/3A, +5V/4.2A
Enclosure Size: 24.5cm x 14.0cm x 8.3cm
Packing Accessories:
3500MGB-Raid Enclosure
USB 2.0 cable
Firewire 1394a cable (6 to 6pin)
Firewire 1394b cable (9 to 9pin)
Power adapter plus cord, feet, screw package, manual
$97 + shipping
LINK
erwos
4,778
I have one of these - it works pretty good. It's definitely a good deal at $97, assuming the place is reputable. Firewire SATA enclosures are just expensive.
My only quibble is that it doesn't have RAID 1 support. OS-level software RAID 1 works pretty well, mind you, but I don't see why they chose only to have RAID 0 on the enclosure itself.
travisray2004
922
USB 2.0 cable
LINK
OMG, they give you feet too... Sweet, my are kinda stinky at the end of the day
