Hi all, I am in desperate need of help as I have messed up my computer in trying to remove Ubuntu so I can install Ubuntu 15. When I boot my computer it is showing a grub rescue error. What had happened was I wanted to delete ONLY the SSD that had Ubuntu on it. I have Ubuntu installed on one SSD, Windows on another SSD and the bootloader installed on the SSD that had Ubuntu loaded.
I decided to use computer management in Windows 10 and formatted the second SSD that had Ubuntu on it. I thought that would of been a quick and easy way to format the SSD to install Ubuntu 15. But now when I boot my computer, it is now rendered unbootable saying error: unknown file system Grub Rescue with a prompt. I tried to change the boot order to the Windows SSD but it still says grub rescue error. It seems that the Windows boot loader is missing. Can anyone please help on how to restore the Windows boot loader? Thanks in advance for any help
Things that were tried so far:
-So I tried bootrec /fixmbr and the operation was completed successfully. Unfortunately the bootrec /fixboot option receives an error "Element not found". Both commands were done with a Windows 8 disc as I do not have a Windows 10 USB. The MS site doesn't have the option to download Windows 10 onto a USB stick on a macbook. They only provide an ISO file in which the macbook doesn't have an optical drive to put into.
-I have tried using the command bootrec /rebuildbcd which results in the same error "Element not found"
-I have tried using the boot repair from the Windows 8 disc. I think I made my problems even WORSE! The repair went under way and was successful. Unfortunately I am now getting a Windows boot loader error (probably because I tried using a Windows 8 repair on a Windows 10 install) "The boot selection failed because a required device is inaccessible"
-I manage to get a Windows 10 USB stick, unfortunately the boot repair option did not work and the computer is still rendered unbootable. Even more confusing, the Windows 10 USB stick is reading my computer as a Windows 7 machine! My only assumption as to why this is happening is because I tried to use the boot repair option from a Windows 8 disc. Even when I try and do a clean install the USB stick is reading my machine as a Windows 7 machine.
-I have used Boot Repair within a LIVE Ubuntu session (Ubuntu is NOT installed onto the drive) without any success. I was hoping the Boot Repair would somehow detect my Windows install but this was not the case.
-I have used Boot Repair again but with Ubuntu NOW installed and unfortunately no changes. I noticed how grub is now on the Windows installation. I am able to boot normal now but the computer is only able to boot into Ubuntu. There is no option to Windows 10 whatsoever in the grub menu. A log of the boot repair can be found here if it'll make a difference.
http://paste.ubuntu.com/12114712
Here are my system specs:
Antec 1200 / ASUS Z77 Sabertooth (BIOS v2104) / Ivy i7 3770 3.4 GHZ / Generic stock heatsink / Corsair Vengeance 8GB 1333 MHZ / SATA3 Samsung 830 SSD 250GB (Win10) / Samsung 840 SSD 120GB (Ubuntu) / 750GB HDD (Data Drive) Radeon HD 7850 2GB / Onboard Sound / Corsair CX750M / ASUS VW246H. Everything running at stock.
Samsung 830 (Windows 10)
Samsung 840 (Ubuntu w/grub bootloader)
Just remember I no longer have Ubuntu installed as I formatted the 840 in computer management in Windows which resulted in this problem that I have now. So now BOTH OSs have been rendered unbootable. I previously thought that the Windows boot loader was still on the 830 which is why I formatted the 840. I guess I was wrong. Please any help is appreciated!
Any help would be greatly appreciated.
