Messed up iPhone 5 repair-- help?
desura
4,627
129
101
I replaced the battery. Turned it on before shutting the case. Worked fine. Turned it off.
Messed up in putting it in at the wrong angle. After taking it out and putting it in at the right angle, now it will not turn on at all.
Any ideas?
isekii
28,578
take it apart and put it back together again making sure the connectors are all secured.
Sep 29, 2004
18,656
67
Lol, apple. . Destroy it and buy a phone at 1/3 the cost that does the same thing?
You're trolling. If that's the best you can do stay out of the thread.
esquared
Anandtech Forum Director
desura
4,627
129
101
Also,
The phone still syncs to my computer. So I'm guessing I somehow damaged the display?
nickbits
4,122
triple check that the all the connectors are attached. if so, time to buy a new phone
