- Mar 17, 2005
- 687
- 9
- 91
Looking to set up a mesh Wifi network in my house. I have an Ethernet backbone running across the ground level to the basement, so I can set up two nodes on ethernet. It would be nice to have a third node on the 2nd floor, though not critical. My Netgear R6400 is delivering 200 Mbps (per speed test) to a desktop in the 2nd floor office.
Specs
House is only 4000 Sq ft across three floors. Colonial, so a fairly compact box.
FIOS Gig connection installed in a corner of the ground floor.
Ethernet cable from that router to the basement to opposite end of the house. stopping point in the middle to hard wire the connected Blu Ray player with a GIG switch.
I currently run the FIOS wireless and a Netgear R6400. The coverage is OK, but hopping across routers depending on where in the house I am. I tried one of the FIOS extenders, but it didn't have enough range from the installation location available on the backbone.
Requirements
- Strong Wifi across the house. I have a Gig pipe and want to get a couple hundred Megat my end points
- Seamless roaming across access points, hence the interest in "Mesh" vs just adding access points.
- Parental and device level controls would be nice since I have an adventurous son.
- Two nodes can run on the backbone, I was thinking of a third upstairs in the office would need to be wireless. Kids are 10-12. Who knows where things will go in the next 5 years.
USB ports to attach media drives would Be nice. I have a NAS, but also have a bunch of Terabyte drives building up as I migrated kids notebooks to SSDs. I figure I can hang those off the network as backup servers
- Reasonably Easy to administer. I've heard the Linksys stuff can be a bit touchy to set up. Google seems like the Apple version of Mesh. I'm looking for something in between. Probably don't want to go all the way to a commercial (ubiquiti?) implementation. I only know enough to be dangerous.
Which brands? Netgear Orbi? others?
Thanks
Specs
Requirements
Thanks
