NFS4
:Q:Q
http://autozine.kyul.net/0_News/Latest/Current/News_frame.htmOne and a half year ago, ZF introduced the world's first 6-speed automatic in BMW 7-series. Soon, Jaguar S-Type, XJ and Audi A8 also adopted the ZF transmission. Not Mercedes, because Mercedes is the only car maker in the world building its own automatic transmission (GM and Ford builds via their subsidiary, while other European car makers simply out-source from transmission makers). Mercedes used to be proud of its smooth 5-speed automatic, which is fitted to almost all its models from C-class to SL-class. However, being short of 1 gear, it is bettered by the ZF unit in acceleration, smoothness as well as fuel consumption.
This will be changed from this Autumn, when Mercedes start producing a new generation 7-speed automatic transmission, called 7G-Tronic, to replace the old 5-speeder. Initially, it will be used by the V8 models only, such as E500, S430 / 500, CL500 and SL500.
With 7 ratios, expect it will take the lead again in the competition with ZF. More ratios means two benefits: 1) smoother shifting and acceleration because the ratios are closer from each other; 2) better fuel economy because of larger ratio spread between the lowest and highest gear. In the best cases, fuel consumption can be reduced by 0.6 litre / 100km while 0-60mph time is cut by 0.3 seconds.
The 7-speeder is barely any longer and heavier than the old 5-speeder, thanks to clever packaging and magnesium casing.
