- Aug 10, 2005
- 17,768
- 485
- 126
NEVER had a problem with stability and Memtest was run by accident - leaving a boot cd in the machine. Found system process halted by exception (in memtest - WTH?)
Sooo I reboot (hard reset was required) and let it fire up. Fine until test six. BAM! Ton of errors! Bring everything back to stock, try again - same results. Fine, removed two sticks of ram - same results. One stick, ditto. Tried different RAM - same results. Tried UNDERCLOCKING CPU AND RAM - same results!
This system is what I would call stable - it will do LARGE memory test Prime95 for days without a hiccup. I've seen systems that flunk Prime95 and will do the same in Memtest. I have NOT seen a system that takes an immediate dump (on test 6) in memtest yet passes any other test in Windows. Makes no sense!
_____________________________
System Specification:
AMD Athlon64 FX60 CPU cooled with Tuniq Tower Heat Pipe
Asus A8N32-SLI-Deluxe motherboard with latest OFFICAL BIOS
Corsair TWINX2048-4400 PRO (2 for 4096 MEMORY)
ATi Radeon X1900XTX PCI-E Graphics Adapter (1)
Enermax Liberty 620W PS
150 GB RAPTOR x 2
500 GB PATA Hitachi HDD 16MB (On nVidia RAID using a thing called a "seriall")
NEC 3550A DVD-RW DL
AGERE 1394 TRIPLE
Toshiba DVD reader with hacked firmware for true 16X DVD movie ripping
Edirol FA-101 PCM recording interface
CL SB XFI Elite Pro
Win XP 64 bit SP1
_________________________________________
I REALLY hope this is a glitch that can be ignored. It is a real PIA if I have to RMA anything!
150 GB RAPTOR x 2
NEC 3550A DVD-RW DL
AGERE 1394 TRIPLE
CL SB XFI Elite Pro
Win XP 64 bit SP1
