R Ruger22C Golden Member Sep 22, 2006 1,080 4 81 Oct 23, 2010 #1 The .iso won't load. I press 1 to choose single cpu, it says 'loading memtest' but doesn't get beyond this. Now, I'm using 95% or my RAM in windows, and nothing is crashing. LinX is using most of it, and reports 0 errors. Am I good???
RebateMonger Elite Member Dec 24, 2005 11,586 0 0 Oct 23, 2010 #2 Just to be sure: Is this the version of Memtest you are using: http://www.memtest.org/
razel Platinum Member May 14, 2002 2,337 93 101 Oct 23, 2010 #3 Agree. I never had to press any button to start the test on any system (single, dual, quad) after the iso begins booting.
R Ruger22C Golden Member Sep 22, 2006 1,080 4 81 Oct 23, 2010 #4 I used this.. http://www.memtest86.com/
R Ruger22C Golden Member Sep 22, 2006 1,080 4 81 Oct 23, 2010 #5 Okay, the one you linked loaded.. I let it go to 10% and then decided to finish later. Thanks.
