MemTest Errors.. Help... Thx..
j@cko
I have a pair of 512mb BH-6 from OCZ and I ran MemTest on stock voltage (I used default from mobo) and stock timing (2-2-2-7) also 2-2-2-11. By the way, my mobo is 8rda+ rev 2.1.
Whenever I run the test, I always get errors in Test#5.... I mean, is this normal.....?
Thx
Thx
no errors are normal 🙂
try upping the voltage up a little and see if that clears things up... voltage meaning the vdimm voltage on yoru epox
Thx
hm.. did you mean, "no errors are normal" as, having errors in this test is normal? Or you meant that it shouldn't have errors?
should not have errors is normal..
do you overclock your PC to over its stock frequency?
If yes, do bump your Vdimm a little, by 0.1v
and try running it again.
If you are running everything at stock or below..
and it gives you errors,
then I think you should RMA it
